there is some problem
5 replies · 2,316 views · Started 17 August 2002
i tried to change the operator logo like what you said
but it not change ?? i dont know why?
i am from kuwait (wataniya telecom co.)
319-03-0 <--- correct ?!
and the file name "319_03_0.bmp" <- correct ?!
this file under oplogo folder <--correct ?!
so help me plz!! thanx very much
[email protected]
leave out all leading zeros ... your filename should be "319_3_0.bmp"
Same here, I need advice too.
I did what what you said as well, but for me is UK vodafone.
Is that right ? If it's right then I don't know what I've done wrong.
As I have created all the folders I suppost to.
Thanks.
