A Gift from me to the N-Gage community: WATCH MOVIES ON YOUR N-GAGE!!! yes its free!
77 replies · 55,771 views · Started 02 November 2003
OK this is for all of those groups of people who either love, hate, or are bias about the N-Gage.
Hopefully more will appreciate what it can do after you all read this. Just remember that
symbiamaniac was the first ever to post this.....
As a free gift from me to the N-Gage community, here are detailed instructions i've created on how to
encode and watch ANY movie clip or full length movie on your N-Gage at the highest resolution and
color quality the game deck is cabable of......First, some quick facts to make your mouths water:
1) Encode and watch Full length movies via 3gpp media format (your realone media player will play
this perfectly).
2) Average 90min movie @ highest 15 fps in stereo is only ~50mb. So stock up on mmc cards. I
heard that the N-Gage can only take mmc cards up to 128mb. Thats a bunch of BS! I've contaced
some technical sources at Nokia and they backed me up so I installed a 512mb mmc and it works
perfectly!!
3) Convert all the popular media types to play on your N-Gage like .avi, mpg, mov, ect....in minutes.
It took my p4 1.8ghz only about 10min to convert a 90min movie at max res.
4) So easy that even I figured it out....
OK enough already, life is short....how to convert:
A) You will need the following to play movies:
1) usb link provided with you n-gage
2) mmc (multimedia card) with enough space for movies ~50mb = 90min
3) Now, all you have to do is download one of two applications below:
Nokia Multimedia Converter 2.0
http://www.forum.nokia.com/main/1,6566,040,00.html?fsrParam=3-3-%2Fmain.html&fileID=2998
HELIX Mobile Producer
Sorry, i'm too lazy to provide the link....just do a search on google....Realnetworks makes it.
Nokia Multimedia converter 2.0 is a free app (thanks Nokia!!) and works just as well as HELIX
Mobile Producer (which is a 30 day trial).
B) I highly recommend the Nokia app not only because its free, but because of its simplicity. The only
other thing you need to know when converting to 3gpp format using Nokia MC is to set the fps to 15
for the highest resolution. If you're concerned about file size then, by all means go to a lower fps. The
only advantage about using HELIX (that i've seen) is that you can convert files to realmedia (.rm files).
However, its been a real pain in the you know what getting the settings right. So far i've had much
trouble converting to realmedia files and playing them on the N-Gage. It all depends on what type of
file you start out with (avi, mpg, mov, ect) and how it was initially encoded. With Nokia MC, no
matter what type of file I started out with, it had no problems converting and playing them.
C) use either of the above apps to convert your media file. again i highly recommend 3gpp format.
D) File transfer to your N-Gage is simple....
1) make sure your mmc (multimedia card, which is different than a SD card) is installed.
2) connect your N-gage to your PC via USB link
3) open windows explorer. your computer should automatically recognize that your n-gage with
mmc card installed is attached and it will show your device as an addition hard drive.
4) drag/copy your movie file to your memory card/device.
E) Now this is important!! Disconnect your N-Gage from the USB link. (game deck MUST be
disconnected in order to access the mmc).
F) open realone player, move to right tab to view contents of mmc, hit play, ENJOY!!!!
PS: praise mail is welcomed...hehe just j/k 😃
*praises*
so the realone player will play this 3gpp will it? but its realplayer shouldnt it only be able to play .rm .ram?
Thanks for this. Althought I have try it but this sounds REALLY good. I will thank you here for this REALLY helpful infor and thank you again if it works.
I have another question for you here. MP3 to AAC. I know some other user have post this but it doesnt work for me. I am trying to find a software to convert MP3 to AAC. Earlier Someone suggested iTune for PC but when I convert the MP3 file to AAC format, and they come out to be M4A format, which cant be use on Ngage. Do you know any other way to do it?
Regards.
ceks
Originally posted by audiophile
*praises*
Thats correct, the realplayer on the ngage does play 3gpp files. from what i've experienced so far, it plays them even better than rm files.....strange, i know, but true. why nokia never made this feature known from the start, i have no idea.
Originally posted by ceks
Regards.
ceks
as a matter of fact, yes i do know of such a program....the program i mentioned in my article, HELIX Mobile Producer, can convert mp3s to aac. i've done so with no problems at all....also, you can use either helix mobile producer or nokia media converter to convert mp3 to 3gpp. hope this helps...😊
Hi again!
I have downloaded the MMConverter and tried to install it. But there is a problem. There is a message telling me that "Installer User Interface Mode not Supported". DO you have any idea whats wrong? Do you have ICQ? Can I ICQ you?
Regards.
ceks
Hi again!
Regards.
ceks
You need also to install the latest the latest Java runtime environment 😊 Download from the Sun site here:
http://java.sun.com/j2se/downloads.html
hi guys just wanted everybody to know i posted a short film that you can download and watch....check it if you have time.
-peace 😊
which java file do you need to download to be able to use this converter. there is quite a bit of downloads on that page
I have manager to install Nokia convertor. Indeed it is very easy to use. But I have to download the jave enviroment software from java website inorder to install that.
I have compaired the quailty between Helix producer and Nokia convertor. Helix producer:- better in quality, smaller in file size but screen size have to be force to 176x144, so file will look funny. Nokia convertor:- reasonable quality,bigger in file size but the screen size is perfect.
Thanks Symbiamaniac!
The file name is Java 2 Runtime Environment, SE v1.4.2_01
I have installed the nokia converter along with the Java 2 Runtime Environment, SE v1.4.2_01. I converted a couple of trailers (.mov files) to .3pg. They played (on my N-Gage), but with no sound! I tried converting an .mp3 to .arm and that played fine. Why won't my N-gage play .3pg's with sound? (I didn't try the Helix program because I'm using windows ME and said I need NT)
Also, after encoding with the Nokia converter my PC stopped playing ANY sound at all and I had to reinstall my sound drivers to get it to work again. What's up with that?
Hey guys, how about getting a simpsons episode made for the N-Gage and posting it up. I'd love to see it running.
Is there any links for such movies out there?
Ive tried to download the file but it wont let me, it just says 'page not found' every time i click on the link
Will Apple's Quicktime not do this also. All you need to do is open the movie file, click export in the menu and choose to save the resultant file as .3gp I am unable to test this as I don't have my N-Gage yet. If anyone can check it and get it to work, that would be the easiest method. You will need to have QT Pro though I think.
got nokia converter,wont change any films apart from mp42????why why why why. keeps saying error whats wrong ??help me please???
I've tried this and it works fine. BUT, if the file you wish to convert is not fullscreen 4:3 aspect ratio, i.e. widescreen, the picture will be stretched.
could anyone post the best settings for conversion especially for the sound for the Nokia Multimedia converter. thanks alot 😃
what put any film on ngage how??.download what u said and only film that convert was crappy porn off kazza lite,ive got loads of films toconvert but f?ck all will.Keeps saying error whats wrong,dont lie????, tell me what to do,(1 pisss?d off person).
😱 Not sure where that came from?
If ya need help try being a little more specific as to what the problem is.
Whats the error message thats appears and when does it appear?
Ive just converted my first movie file and it has turned out up-side down, has anyone else experienced this and got and solutions, would be greatly appreciated. Thanks
Robbo
Heya
i was wondering if anyones else was gonna mention this.
The main reason i only use Helix Producer Plus is because i always get the same problem as Robbo.
I havent got a clue how to correct it, so i can only advise you use Helix
sabz sorry 4 my anger,its just that with the nokia movie converter i cant seem to convert many films,it stops when it trys to config the sound,am i doing something wrong??.Need some help with what settings to use please help,(error just says windows needs to close down)?????? HELP ME.
Try contacting Nokia Forums and seeing what they suggest. It could be something thats on your PC thats causing the problem.
Or otherwise use another converter like Helix.
Well I've tried 3 times so far, and it won't install. I get to the point where it says installing Nokia Multimedia Converter 2.0, and gets stuck there. I've even left it like this for 8hours and still it didnt get installed 😡 any suggestions??
thanks.
dont bother to install nokia converter if u got xp home it dont work.
It doesn't make a difference,i just installed it on my other home box which runs XP Home Edition and it does work.
