P800 apps on P900
4 replies · 2,825 views · Started 21 November 2003
I just got a p900 and i want to know if my p800 apps can be installed on it or no?
can someone please let me know
thanks alot
All apps will work with the exception of those coded specifically for the P800's colour palette. Tenis Maniac is the only apps i've found with that problem. The colours come out inverse.
Source: WhatMobile Forum
[QUOTE]Originally posted by omar_g
[B]All apps will work with the exception of those coded specifically for the P800's colour palette.
Really? PhotoEditor dont work, you need to upgrade for 5 Euro. Notepader dont works, have to wait for a new version. WorldMate dont works, have to fight quite long time before to get a new code for free. Four in a Line dont work, have to get a new version for free to install. Software from Symbianware dont work, need to get new codes for free before it works. Quicktimer works but just counting down but no alarm. AgilleMessenger works but the lower part of the screen nearly invisible.
