Crystallized theme for Nokia 6600 is now available for download...
my site has moved to http://6600themes.cjb.net
Follow the instructions in the zip file and please post any problems or comments here...
thankiu so much !!
Is it really done? It doesnt say so in the instructions.
Great looking theme. Can't hardly wait for the finished version.
Pity the download link for the beta doesn't work; can't find file on server: http://www.hostinganime.com/esbalok/files/251103_crystallized6600v08b.zip 😞
Can you post it here ? 😊
There website doesn't like you sitting any firewall, disable it, download OK...
many thanks!
thanks man😊
i was able to download it on my pc. now the problem is how do i save it on my phone? just snd thru infrared then it automatically saves itself in d themes folder??
tnx!!
Read the instructions that came with the theme. Is that really so hard?
The Linux skin works a treat many thanks
One little question: is it supposed to skin the icons etc like the screen shots on the themes website?
On mine it just skins the desktop.
thanks
all icons are skinned, make sure you choose "default" on icons...
how about the others??
Thanks a million ice_cube!
Very impressive work.
Many many thanks.
Waht we need now is a skin switching program that can change the skin with out having to use a filemanager program to rename things.
Many thanks again!
Can someone provide me a space for download mirror for my crystallized theme??
I have empty site http://koti.mbnet.fi/nok6600
mail me nokia.6600 at mbnet.fi
HI!..
No problem...
I have an unlimited quota for data transfer server...
use this link on your web site...
i already uploaded there your skin file...
http://www.modelosv.com/6600/251103_crystallized6600v08b.zip
cya! 😃
OK, I put also the file in my site
Many many thanks for AEFOX and Traktori...!! 😃
Has anyone got a working copy of the original climber theme they can send?
I downloaded one from the website but when I try to load it, it says "File corrupted".
Please help!
the theme itself is cool. works great on my phone. but i think it would be better if the font color of the date (mm/dd/yy) on the main screen will be black or white or anything darker/lighter that it's blue background.
keep up the good work.. Thanks
I wish I could change the fonts color... 😮
I saw some other selfmade themes in german-boards:
there the peopel only put colours like for exampel blue on the small background up on screen.
This is a exampel how they make it.
(not that u should change it like they do, but maybe u make the pink only a small bit stronger?
S�mi
thanx.... very nice
ice_cube
If you're having problems with webspace let me know and I can set you up with some on the AAS server.
I'll mirror your file this weekend in any case.
Cheers
Rafe
Could Someone create a matrix theme ( like the one in the t610) pleaseeeeeeeeeeeeeeeee i am desperate for one
I've been trying to make Climber and Crystalized theme working at the same time. Does anyone know how to do it?
It's quite SO simpel.
Read your forums and find out:
There is allready a Thread about theme's in h�re
Can you send me your matrix theme? [email][email protected][/email] Thanks.
can send to me too ?
thanx
