Is there some sort of app that'll allow you to play/edit midi files and convert them to ringtones?
Midi player/ring tone editor?
If you can get hold of the install files for an old phone like the 6210 (it came with a software CD) there was an app on there by nokia that would read MIDI files and ringtone files and let you convert them around. You could also send the ringtone to your phone via IR. The editing is based on a stave and you place the notes where they go on it, hence unless you know how to read music you'll be scratching your head for a while. It's a good app though and it's helped me make a fair few ringtones.
[quote="Matt_Helm"]Is there some sort of app that'll allow you to play/edit midi files and convert them to ringtones?[/quote]
checkout Mobile Music ringtone composition software at http://www.digibookcase.com
i havent tried this before as i already have ringmaster...
😉 For more info you can also checkout http://mobile-phone-software.com/ring-tones.htm
Have fun!!!
Thanks!
No problemo... hopefully you'll find what u are looking for... and please also update us okay???
