6600 slow down
2 replies · 1,615 views · Started 04 December 2003
Hello,
I installed few applications on my 6600, and now it needs 3-8 secs to open whatever I open...I guess it runs too many applications behind, because the problem is solved with a restart.
Is there a task manager which automaticly close these appls...???
(not manual like applman).
Is anyone else who has the same problem?
thanks anyway.....
if you exit the apps, then it will close. you could've installed so much apps that you don;t need or would not use everyday, or not compatible to your 6600
