i have the agile messanger on my 6600 ...
icq works ...
but i have a stupid problem with msn
the program doesn't tell me who is online & who is not ..
all contact appears to be offline .. but when i send messages ..it gets through ..😕
all i need is someone to tell me .. how to make this software detect online & offline users
thanks
Looks like the Agile Messenger isn't compatible with the 6600, I had this problem before, when the messenger was working.
But now it doesn't connect at all 😕
hmmm...
I have Agile Messenger working just fine on a 6600 here.. well,there is one little glitch,though...
When I'm chatting with someone,there is no box around the text input... it is one with the rest of thre chat screen.. but,that is all.. all other functions are working perfectly!
Cheers
RayGun
HI!
AgileMessenger is not connecting to the Master Server here...
I think in some places is working...
it was working fine some weeks ago.. but not now..
You press CONNECT .. and never get connection to Master server...
cya!
I can connect but I can not get it out of dictionary completion mode,
I want regular text input, any one have any ideas,
Andrew
Originally posted by phpsocialclub
I can connect but I can not get it out of dictionary completion mode,I want regular text input, any one have any ideas,
Andrew
You just press the # key twice and you're out of the t9 mode.. 😉
Mine works fine (Telestet Internet over GPRS, Greece)
If you use WAP over GPRS, Agile Messenger will not connect to any server. It needs Internet GPRS APN (like all Internet applications, Opera, internal e-mail client, Netfront etc.) because WAP access points allow surfing to WAP sites only 😊
Mine works great!
I've just installed version 2.0 it seems they have separate version for each device. Just Try the 6600 version....but still a glitch on apps caption.....
Am using Agile Messenger over T-Mobile WAP GPRS gateway. Its fine. Just set your settings within Agile Messenger to use the right connection. Also there is an option to HIDE offline contacts
what exactly are the right settings you are using for Tmobile?
did you download the latest version?
works great on my 6600, too
