TRANSFER FILES FROM DEVICE TO PC
4 replies · 2,504 views · Started 29 August 2002
anyone know how to transfer file s using bluetoot h connection from 7650 to pc ?
do i need to use the bluetooth software
or nokia pc suite for 7650?
i try to send snakeEX files from my device to my pc but it always failed
anyway i seldom play the snake things so i want to remove the game from my 7650 to free some memory.
but dun want to lose the program
cause i might need later on
so i want to keep the snake EX data on my pc instead.
any help ?
Nokia pc suite for 7650 gives you access to your phones drive(s),
SnakeEX comes with the phone and is stored on the ROM Dive Z:,
if I recall this correctly. If this is indeed the case you're never able to remove it.
Even certain Filemanagers installed don't allow me to copy anything from the Z: drive.
i can copy the files from drive :Z
to drive :C
and delete files from drive :Z using seleQ as long as you remove the read only option first.
but the problem is i can't send the file using bluetooth to my PC. 😞
[quote="deevonn"]anyone know how to transfer file s using bluetoot h connection from 7650 to pc ? do i need to use the bluetooth software or nokia pc suite for 7650?[/quote]
You will probably need both of them. It depends on what kind of a Bluetooth device you are using.
Here are instructions for the 3Com USB-Bluetooth adapter + PC Suite for 7650 + 7650 phone:
http://www.my-communicator.com/www_news/article_eng.php3?id=578&group=My-7650.talk.english - maybe you get the idea from this. Or then maybe not, hard to say since you did not tell what kind of hardware you are using.
You will absolutely need PC Suite. If you didn't get a CD with your 7650, you can download the program from Nokia's website: http://www.nokia.com/phones/productsupport/7650/downloads_pcsuite.html .
Tero
