i must clean the screen from the inside!There is a huge trash 😞
I removed the cover from the antenna,unscrew the four screws,remove the cam and to continue i must remove the keyboard.There must be a trick but i didn't make it..Please can u help?I know that maybe loose the guarantee but i dont care
Thanks for the help[/b]
How can i open my 7650?
Dang! I know I was reading a web site today that explained how to take one apart. Serious!
But do you really want to open it? How about you try and blow into it really hard, maybe using a little pipe and those PC cleaner kits you can get? I don't think that opening it up is a good idea (even if you're clever - like I'm not).
[quote="TANKERx"]Dang! I know I was reading a web site today that explained how to take one apart. Serious!
But do you really want to open it? How about you try and blow into it really hard, maybe using a little pipe and those PC cleaner kits you can get? I don't think that opening it up is a good idea (even if you're clever - like I'm not).[/quote]
i tryed to blow into it but nothing happend 😞
I would really appreciate if u can find this link..
I have a very good video for this sort of job but it's 14 meg 😮 is size, more than happy to send it to you if you have a mail box which can take that size. 8)
Take 2 toothpicks, open the cover, and insert them on the sides (near the edge of the cover). Push them down hard, then you'll see the cover can be slided down. It's a bit tricky but after opening it 5 times, you'll get the ideea. Don't pull the cover too hard ! You might break the connections between the boards.
[quote="Deezel"]Take 2 toothpicks, open the cover, and insert them on the sides (near the edge of the cover). Push them down hard, then you'll see the cover can be slided down. It's a bit tricky but after opening it 5 times, you'll get the ideea. Don't pull the cover too hard ! You might break the connections between the boards.[/quote]
Thanks for the reply.
U mean the cover of the antenna?do i have to unscrew the four screws or not?
[quote="lonegunman"]I have a very good video for this sort of job but it's 14 meg 😮 is size, more than happy to send it to you if you have a mail box which can take that size. 8)[/quote]
check your pm's 😉
@Global moderator
Did you get the video as I left it to upload and send as I was going out, if you got it is it any good for what you want? 😃
[quote="lonegunman"]@Global moderator
Did you get the video as I left it to upload and send as I was going out, if you got it is it any good for what you want? 😃[/quote]
Thanks for the try..
I receive a blank mail 😞 (with no attachment)
OK, I will try again, sorry about that. 😮ops:
[quote="Global moderator"][quote="Deezel"]Take 2 toothpicks, open the cover, and insert them on the sides (near the edge of the cover). Push them down hard, then you'll see the cover can be slided down. It's a bit tricky but after opening it 5 times, you'll get the ideea. Don't pull the cover too hard ! You might break the connections between the boards.[/quote]
U mean the cover of the antenna?do i have to unscrew the four screws or not?[/quote]
No, i mean the keyboard cover. Slide the keyboard down, and insert the toothpicks on the top side of the keyboard cover, on every side. The ideea is to push the kbd cover from the display cover so it will slide over the notches that limit its opening distance.
[quote="lonegunman"]OK, I will try again, sorry about that. 😮ops:[/quote]
i receive the attachments.Thank so much..
cheers 😊
Thanks Deezel for the information 😊
No worries, Just as long as you can make some use of it 😃
Could I have them too, please?
Thanx in advance..
hello,
I am really interested as well.
Where can I find the video that explain how to proceed ?
Thanks in advance
Bye
Scrameustache
hey can someone send me that video,thanks
can any one please upload the video to some free file servers and link it here....
like rapidshare or depositfile etc etc...
