was able to install Realone... n...
8 replies · 2,738 views · Started 02 September 2002
was able to install Realone... n... i found somew clips for it. now d problem is, i sent d video thru my ir port, then it says unkown format? cn anyone help? i dont know how to use realone how cn i put my files??? 😊 :-? 😊
go
http://www.realnetworks.com/mobile/nokia/get_started.html
and learn more. Anyway, I haven't read those things yet. May try later if have time. I guess with the realone player, you start to see how less the memory 7650 has.
found videos for it... now there's a new problem... i dont konw which conection to use! :-?
hav try connected to www.real.com/7650, when tried to download those rm video, the realone player was started, loading and then timeout, using gprs. Anyone successful?
do you acctually see this page? My 7650 only displays wml code, not the page itself.
When try to watch/listen via gprs all i can see is "connection timed out..."
same here... mine just asks wt conection to use... like the gateway... ut any that i use wouldnt work.
[quote="Anonymous"]do you acctually see this page? My 7650 only displays wml code, not the page itself.
When try to watch/listen via gprs all i can see is "connection timed out..."[/quote]
I had the same with the WAP browser, but I did get hold of the URLs and used the method here http://www.allabouter6.com/phpBB2/viewtopic.php?t=2004 (I posted this without logging on - oops).
