Anyone know how to move down to a new line when entering notes. the manual says enter the 0 key twice but this does not work.
new line
You gotta tap the 00 very fast and the Carriage Return symbol will appear briefly before moving you to the next line.
Failing that, press * for the character map and the Cariage Return is the very last character available.
But again, if you want the 00 route, you have to type the 00 very very fast.
Thanks. I can select the Carriage Return symbol from the symbols box now but no matter how fast I try I can't use the 00 method - could I have turned this option off some how? I consider myselft to be a fast txter.
hi, u don't need to be very very fast typing 00, it actually typing 3 times 0, that's it '000' then u can see the carriage return symbol. In a short while it will goes to next line.
