Screen cleaning
5 replies · 2,432 views · Started 02 September 2002
Hello out there,
what is the best way to clean the (inside) screen without doing any harm to my 9210? 😉
Any help appreciated, thanks!
Regards,
Tilman
One suggestion is the soft 'dry clean" wipes you get at Opticians for glasses. This uses to work wondes on my S5mx and 3c.
[quote="upponalle"]
[/quote]
You might check out the screen polish that Klear Screen sells. It's endorsed by many of the high-end LCD vendors out there, including Apple and Silicon Graphics. I've used it(with the battery out, of course) and it makes the screen sparkle. Quite nifty.
Good luck,
MB
