Hey Guys
Need your Help. Like to ask if you install realplayer in your nokia 7650,Could you play Ram Files...by not using internet... :-?
If Yes you could play ram or rm file in nokia 7650. that mean we could listen to music 😃
Please let me know ok...i'm doing on this thing now
Thanks guys 😃
Anyone try use Realplayer to play music on nokia 7650 before 😮
hi, hav tried rm files on my 7650 but I guess those are the reduced bit rate compilation so the streaming not really that smooth. But with the only 4M of memory(it should be much less in view of u hav others bunch of applications already installed), there's no point download rm files to your phone. I guess its for streming rm files from web sites but so far hav not been successfully done so.
Hey
Thanks for the reply 😊
Could Realplayer play offline file 😃 I have a few song with 500KB - 800KB . if you want the song i could email to you and you can try it 😊
Hey
