Hi guys,
Just tried switching my 7650 on but all that happens is the screen light comes on for a few seconds then goes out again. I have also tried plugging the charger in just incase the battery did not have enough power in it to start the phone but found it wont charge.
I have also tried leaving the battery out for 24 hours.
It was working perfectly well prior to this.
Any ideas guys? or am I stuck with using it as a paper weight?
Apologies in advance if this has been covered before but when I searched I could not find anything that quite matched the symptoms I have got with my phone.
7650 wont power up
had the same with mine .you really have to press hard keeping your finger on the button, mine is knackered now so i need a new button or new phone the non existent sendo x
Tried that but no luck.
Might be tempted to try it with a sledge hammer tho?
It will show a indication of charging , if still accepting even when switch off (lookin upright corner)
Also make sure u let go (ie dont hold while its just about to turn on as this can trigger a turn off),
There aint no indication of it charging in the top right hand corner. And I have tried pressing it lightly but still no luck.
I am getting black lines across the screen now so it looks like a trip to my local service centre.
