hi
any software out there where i can create and upload the ops logo? i have logomanager but it doesnt support 7650.
any software to create and edit my ops logo like logomanager
Coming soon on www.celesta-lifestyle.com
It�s a program to install on your phone, not on your PC like Logomanager.
Regards.
Finally some smart people are making the app I have been looking for.... 😃 No more fiddeling around in the phone to change to a grapphical Operator Logo, and Group graphics...I cant wait for the release.......
but I guess u have to change it everytime if the signal change from 1 telco to another telco when come to oversea roaming. For me, using seleQ, i created a few op logo code for different telco for the country that I was roaming. So, it auto change the logo whenever there is signal changed.
Operator Logo ? I suggest you should just take photoshop(or any graphic editor ) and make a color operator logo and save it as BMP..as long as the dimension is 97x28. Someone posted the instructions to change operator logo in the forum. You might want to look at it. I've changed mine to a color logo..forget about those black, text logo. Color is the way to go if you are using a Nokia 7650.
