I get "App. closed - Sound Streaming !" error and loud beep tone when i close off some program.
I get that error also when someone call me while i use one of those programs.
For example: Smart Movie and Mau Mau.
It's very strange coz i didn't get that error on all programs.
Some programs works well but some programs makes that error when i close it or on phone call.
Is there anyone has a idea to solve that problem ?
Should i do a fulll format to phone ?
Help! Help! Help! :In the end sank like the titanic:
What it is, is that you haven't exited the program properly. You must always go options then exit otherwise that will happen and if you hold the menu button you will see that it is still open. Hope hat helps you mate.
thanks but that's not a case about misusing...
Happens to me with Smart Movie too, I thinkit is a bug. I also get some sort fo screen saver daemon error every time I reboot the phone. It is annoying but too hard to pin down exactly the source of the error without wping everything and starting againwhich I don't have the patience for.
Sounds like 6600 incompatibily problem - those programs work fine on my 3650.
I get the sound streaming error if I try MP3GO on a 6600.
Will
I get that too!!! But I use Mp3Go with no problem at all!
I also get this message when I closing/exit my UltraMP3 Program in Nokia6600. Can Any1 solve this problem?
Thanks......
Same here!! Anyone can help us out???
Thanks.
it's mainly becaouse of different os versions. those vendors should upgrade their programs to symbian 7.0s, to work properly on 6600, 6620 etc.
btw, you can kill that task with AppMan.
Yeah I get the same problem with Smart Movie when I exot using the programs own menu but seems fine when I exit using op menu.
Originally posted by x-daemon
it's mainly becaouse of different os versions. those vendors should upgrade their programs to symbian 7.0s, to work properly on 6600, 6620 etc.btw, you can kill that task with AppMan.
Could U explain a little bit about it. Regarding kill with AppMan.
Please help.😕 😕 😕
me too on my 6600 its mainly smartmovie that says "app closed sound streaming" dose anyone know where i can aquire a newer version of it??????? an possibly a newer version mp3 player coz this crashes somtmes too 😊
