Is there a SMS counter app for the 6600?
SMS counter?
Yes.
And where i can buy it? And whats the name? I found one, but it only works for 7650 and 3650.
Dashfly Minutes will work well, I think current version is 2.1
there is also a program called minutes manager by Moov Software which works on 6600 if you disable the Moov Helper.
Adam
It seems dashfly doesn't have a version for 6600 yet...
Are there any other programs that monitor your minutes, SMSes etc.?
the counting function of Dashfly works fine on my 6600.
and yes if you read my post there is another one below.
LOL
I meant other than the 2 you posted 😊 And thanks for the advice that it works!
I don't know I am still looking, I tested the Moov Minutes manager with the developer to sort out 6600 problems and they are releasing a new version in the near future.
I wouldn't recommend paying for either of them as they are not fully working on 6600. But I certainly have the sms counter capability.
Originally posted by Adam
I wouldn't recommend paying for either of them as they are not fully working on 6600. But I certainly have the sms counter capability. [/B]
Which is why I asked whether you know about others... can't find "test versions"
Minutes Manager 1.3 by Moov Software is compatible with the 6600 and all other Series 60 devices. A trial version can be downloaded at http://www.moovsoftware.com/mm_home.htm . Follow the "download free trial" link at the right.
ELog or E(xtended)Log by Psiloc.com also looks after your minutes, data and sms details.
All these programs I find cannot deal with one problem with billing in the UK though: when you run out of free minutes it ties to tell you how much extra you are spending, but if I am calling a land line, same network mobile, other network mobile or international it can all cost different prices per minute and there is no way of setting them up differently, OK if the program allowed it I could tell it to look for different prfixes, but with mobile numbers it won't matter because people can take their number when they migrate networks.
Eulogy wrote:Is there a SMS counter app for the 6600?
Yes SMSCounter by AngrySoft, sorry I havent got an address for it at the moment. It works very well on the 6600.
It tells you how many texts you sent and recieved to EACH contact and it gives you monthly totals and all sorts. Well worth the $3 or so reg fee
