os6 on my sx1
3 replies · 2,327 views · Started 25 February 2004
i want to update my xs1 with the firmware SX1_BENE-RETAIL-uk-fr-nl_06_0001_update.exe
and if i look in the config of my computer then the phone is conected to com 3
and the program can not find the phone
i can not put the phone on com 1 because that is not a usb
if i look in mrouter then i see only com 3 and infrared
the phone can also not communicate with outlook
can some one help me thnks m8's
In order to update your phone first you need to have the battery fully charged.
Run the updater and when the program asks you to connect the phone:
a.Turn off the phone
b. Turn it on BY PRESSING THE JOYSTICK AND THE HANG OFF BUTTON AT THE SAME TIME (this way it turns on in update mode)
c.Connect the phone
Windows will ask for (the special update) drivers. Select the folder in which is the updater executable (this is where the drivers are extracted after running the update program). After windows recognising the phone the update (devided in 4 parts) will take less than 15minutes. Don't do anything during the process of updating like running other apps on the computer, just wait patiently...
thnks m8
he is working but i can not instal him because my software is new
but i want to have dutch version on my phone
so i have to wait longer
thnks m8
If you go to a Siemens Service Center and ask them politely to upgrade your phone with a different language firmware version they may help you. The latest firmware on the SSCs is fw07. It is rumored that siemens will upload the self update of this version on the internet soon, so may not have to wait too long...
