Can Not Figure Out How To Uninstall PC Suite
4 replies · 2,689 views · Started 25 February 2004
When i try to uninstall my pc suite for my nokia 3650 it says it cannnot find the installer??? and then closes itself. How can i uninstall this software?
It wont let me install it it says this version is the same version as the one that is already installed installation is cancelling...
What can i do now?
go to run in start up then type regedit and press ok and it will open a box in there find it then deleat it i had the same problom i just found out a few day a go hope that helps bye let me no how u go on
kastel86 wrote:When i try to uninstall my pc suite for my nokia 3650 it says it cannnot find the installer??? and then closes itself. How can i uninstall this software?
Delete the folder: C:\Program Files\Nokia\PC Suite for Nokia 3650\ and the try to install it again i u want to 😃
