Can't find the files i transferred...
2 replies · 2,342 views · Started 09 September 2002
Hi folks im sorry if this question already has been answered here but i couldn't find any hints so here it comes: i wanted to transfer a wav to my phone and there fore to test the xp transfer feature i started to transfer a small txt file..53 kb but after the transfer i cant find the txt file (im using Emanager) and stupid as i am i also tried with the wav and also that i couldn't find.....where should i look for these files guys....btw it's that little icon that pops up on ur desktop when you connect with iR...named send files to another computer ...or something similar....plz give a hint
HK
wav files is stored under c:\nokia\sounds\digital
while mide store under c:\system\sounds\digital for txt i've not try yet. Anyway u can access this sound files under extra\recorder
Initially though, you should check your messaging app, as all transfers to the 7650 are considered to be "messages" prior to saving them as files.
