It says on http://www.mobilefun.co.uk/product/995.htm that the nokia 7650 can only down/upload pictures and nothing else at the moment
Is This True Please.
Many thanks again
does the MA620 USB Infra Red work with the 7650 please
i'm using ma620 with windows xp now, working perfectly with nokia suite and u can down/up load any files thru PC as well. No problem.
it mentioned only can down/up load pictures in the website, I guess it mean u can only do that direct with PC and not with their software Headset Manager, that's what I facing too. You don't need their software to do the up/down load job, your PC and the Nokia suite if more than enough for u.
