Theme Editor's
66 replies · 22,309 views · Started 10 March 2004
Correct me if I'm wrong but there are two 6600 editors out there right now.
Nokia's Theme Editor
Microforum's Theme Editor
Nokia's theme editor is slow and has problems saving certain icon's when making a theme i.e.
conn manager
about (on top)
voice mailbox (on top)
speed dial (on top)
sync (on top)
log (on top)
Otherwise it's a fine editor but pointless for a full theme if you can't save icon's with it!
Microforum's theme editor seems to be a little better but has a few things that niggle away when doing a theme, such as..
Can't change the colour of the date in the middle of the screen
The bottom section (with the selection keys on) has to be the same for the whole theme. Looks stupid for the other pages like menu etc...
Anyone got any workarounds for these gripes?
Originally posted by garyparson
no one want to comment/verify these points?
I wish I could help but Ive got the nokia version myself and cant seem to change the colours of the digital clock or signal/batt for some reason, I must be stupid or something,
Terry
you can change those colours, and i'd give you more info on that but i'm on a computer without the nokia editor at the moment. But you can deffinately do it.
He knows it can be done,
And i have said how to do it,it just isnt happening for him!😊
Does anyone know about the icon thing?
Has anyone tried changing ALL the icon's and seeing if they are not named correctly?
Also, I've seen theme's created with the microforum one that has the bottom section different on the menu screen so which bit do you change for that section? The idle screen is obvious cos it's a certain size but there isn't another template the same size for the menu etc.. or is there?
in the nokia one maybe but i asked about the microforum one! non of the sizes match up but you must be able to do it cos i've seen themes created with it.
Also how do you change the date colour? this also must be able to be done as people have created themes with different colours!
Hi mate, Ive put my order in for the microforum theme editor as Im getting fed up with how restrictive the nokia one is. Elton told me how to change certain parts of the theme but I cant seem to get it to work. Is the microforum one any better?
Sorry Gary,
I thought you meant Theme studio,I cant comment on microforum as i obviously use theme studio which i have no problems with!
Has anyone that has problems with it tried re installing coz when i first used it occasionally it wouldnt save edited sections so i re installed and it has been fine ever since!
Also it was definately much quicker the second time,as if it didnt have so much to think about,it now only takes about 5 secs to update the preview which i think is the main cause for the speed issue!
But you can't do the icon's properly with that one can you? Certain one's don't work, unless you've sussed it out.
I'd like to create a full theme with icons an all. Surely you can do it cos others have. Either that or the themes with icons are created using the microforum one and they all have the same bottom section.
I'd say it was easier but there's no instructions and you have to figure where all the graphics go. On the whole that's not that bad. The only things i don't know how to do are..
1. Change the colour of the date in the middle.
2. Change the bottom section when it's in menu view (which you can do with the nokia one)
Saying that, the nokia one has a major flaw in that there seems to be a problem with the icons and when you view your theme some of the icons don't show on the phone!
If you read my gripes with each one you'll see why you can't do a full theme with either. Unless someone would like to share the info with us.
Have you tried (copy originals first) editing the base grafics in Program files/theme studio/data/skins dir?
I know this is a pain but good for icons (depending on how many sets you intend on making).
I've tried editing the existing icons and batt/signal etc but when you try to put them back in the white part isnt transparent anymore, do you have a good icon editor program that might help elton?
I've just got the signal icon to change sort of how I wanted it to, thanks elton, if you could let me know a good icon creator to get hold of though that would be great, cheers
Terry😊
Sorry mate i dont do icons,
There are so many good icons out there already so i just select these to my themes,(coz its too easy i guess lol).
Keep up the good work icon makers,and hurry up Tel,coz i wanna use yours lol.😊
ps: You say it doesnt remain transparent anymore,did you edit the mask?
I like the lazy idea, where do you get your icons from? and yes I've just sussed the mask thing. Once I've done some decent icons I'll send you some ok, lol,
I downloaded the microforums editor, but when I try to open it, it says out of memory. What am I doing wrong. I want to create a VW theme, using the touran or Caravelle, as the background, and have the VW badge as the clock. Not too bothered about the icons, just want to have a different VW theme that means something to me.
You could always download the one thats been made already and set your pic as wallpaper,i know its not the same but it meets all your requirements above!
I was just wondering how do I upload a theme to the web and where is the best web site to post it to
Just another quick question though on the symbian theme upload site how do you get a jpg image of your theme, I've looked in the folder of the theme but cant seem to find one, they're all bmp
Open the image you have with "Paint" then click "save as" and change setting to jpeg.😊
Cheers I've just uploaded another theme, this time with a pic, by the way nice futurama theme elton
Cheers Tel😊
