Is there an app that will let me configure call diverts according to profiles?
What I mean is... let's say I change profile to meeting or silent and I want all calls coming in going directly to voicemail. Is there an app that will change the divert according to the current profile, without me having to manually change the diverts?
Thanks!
MINIGPS might do it - not really sure though - GOOD QUESTION AMIGO and one I would like the answer to.
Thanks for your suggestion, however... minigps will not do what I want.
I just find it a pain having to manually change my call diverts everytime I change profiles. Divert settings on the 6600 are hidden in the settings folders and it takes a lot of clicking to get to them.
I wish there was someting that would synch diverts with profiles.
"Where I am" (http://www.psiloc.com/?id=prod&nrp=104) ... may also not help you then ...
But maybe you can contact some of the developpers - maybe they implement it on "WhereIam" or "miniGPS" ... because that sound helpfull ...
