Nokia Series 60 Theme Studio - How to get it working in XP
59 replies · 133,685 views · Started 23 March 2004
This question is coming up time and time again, so here it is:
Download the application from Forum Nokia.
Right-click the newly downloaded file and click Properties.
Select the 'Compatibility' tab.
Tick the box 'Run this program in compatibility mode for' and select Windows 2000. Click OK.
Then load the application. All should be well.
Have fun themeing!
Oh and don't forget to tell them that it IS that slow, it's not just your computer!
And..
Not ALL the icon's will work... About 5 or so don't wanna play ball for some reason.
Halleluliah! (if thats how its spelt)
The w,i,n,2,0,0,0,c,o,m,p,a,t,a,b,i,l,i,t,y buttons were all starting to wear down on my keyboard lol.😊
Thanks, I was just about to erase the installation files, when I found this hint. I've learned something new.
Best greetings from GER
picadilly
People just search the forum! So we don't need these threads! 😡
j2k wrote:This question is coming up time and time again, so here it is:
Have fun themeing!
Hey there. I downloaded the Theme Editor from Nokia Forum and tried your tip. However, I just cant find the compatibility tab in the file's properties though! I'm using Windows Me. Thanks for the help man.
It works on ME if it doesn't on your comp it means that your comp is way to SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
hi. . . i have this nokia studio theme. . . when im saving the theme that i made it says "theme creation failed. . . see report". how am i going to save it to sis file? please help. . . thanks a lot in advance 😊
this is possibly due to one of the graphics files. I'm on a different computer right now so i can't check the exact name but the graphic file that is the highlight in a menu screen has to have a blank pixel in the top and bottom right corner if i remember right. failing that, try one of the original componants to see if it works with your theme.
When I have just added a new thread about this, now I install the app perfectly 😊 Thanks.....
Anyone notice a difference using your machines default jvm vs the 'recommended' one?
speed/stability?
hello,
where can i find theme builders for nokia 6600?
what do you mean by (Download the application from Forum Nokia.)?
thanks
Have fun themeing!
hajjash wrote:hello,
Direct your web browser to http://forum.nokia.com/ and register, search for "Series 60 Theme Studio", download & install.
they mean go to forum.nokia.com or whatever you call it and download the application
Banned
You have been banned from Symbian Themes.
Therefore, you cannot download or upload any themes
this massege is always display on me ? why
eraqish wrote:Banned
You being banned from symbian themes has nothing to do with the subject of this thread.
The answer to your question is here
"theme creation failed. . . see report"... i am also gettin the same message... garyparson can u please help a lil mo? i was really unable to understand your post!!!
slaysatan wrote:"theme creation failed. . . see report"... i am also gettin the same message... garyparson can u please help a lil mo? i was really unable to understand your post!!!
I will post the answer to your private message for the benefit of any one else with this problem.
Here....
There is an bug/error with the 'List Highlight' go to Highlights/list in theme studio and edit the image so that the corner pixels (Bottom left and top right) are of the same colour,difficult to explain this but,its the bottom left corner pixel and the one next to it,and the top right corner pixel and the one below it. Hope you understand?
hasn't nokia made a theme editor that works well (not really realy slow)??
why?
i can't run the theme editor on my pc its just soo slow, i cant bear it then it crashes.
cuddlers89 wrote:hasn't nokia made a theme editor that works well (not really realy slow)??
why?
No they havn't yet,
I take it you have the latest one? which is faster,but still slow. 😡
As far as the pc crashing,all you can do is increase your virtual ram,and make sure you have no programs running before you open theme studio (even better,restart before using it) but what a pain in the arse eh!
jw wrote:This question is coming up time and time again, so here it is:
Have fun themeing!
HI SORRY WERE I CAN FIND THE DOWNLOAD THE APPLICATION, FORUM NOKIA
playboy4fun wrote:HI SORRY WERE I CAN FIND THE DOWNLOAD THE APPLICATION, FORUM NOKIA
Why is it so hard to find? The instructions before seem to be clear enough, in my opinion.
Did you go to http://forum.nokia.com/ to look first (before posting your question)?
If so, did you look at what's downloadable in the "Tools" section?
If not, did you try the "Search" field in the upper right-hand corner?
Did you try search words like:
"theme" -> 1st result is Series 40 Theme Studio download, 2nd result is Series 60 Theme Studio download
"studio" -> 2nd result is Series 40 Theme Studio download, 4th result is Series 60 Theme Studio download
"theme studio" -> 1st result is Series 40 Theme Studio download, 2nd result is Series 60 Theme Studio download
"series 60 theme studio" -> 1st result is Series 60 Theme Studio download, 2nd result is Series 40 Theme Studio download
