Hi all,
Any tips on this one? My Sx1 will not uninstall expired symbian applications...
I go to menu>setup>Manager---->it prompts me "Manager system error"
im using software ver 6.
Thanks Kudoz.
rv ice
Hi all,
Thanks Kudoz.
rv ice
I had a similar problem.
If it is the same then one of the sis files at C:\system\install\ must be corrupted.
To solve the problem either...
a.Try to restore a backup and see if the problem is gone.
b.Try to move all the files on this folder to another folder using a 3rd party file manager like FExplorer,Seleq, Fileman,etc to another folder (eg. c:\temp or better to a folder on the MMC) if you find any problem moving a specific file then this file must be corrupted. Delete this file and reinstall the app that corresponds to this file. After finding and deleting the corrupted file(s) move back all the files to C:\system\install\
Hi MemphisX
Thank you for the info.. I will give it a shot then update you guys what happened!
Keep them coming mate!
Godspeed,
Rv ice
