3660 System Error when openning Stools
6 replies · 2,590 views · Started 26 March 2004
My Stools was working quite well when after a few programs installed it wont go to the Tools tab with out the "System Tools: System Error" message. Dang!
Should I do a format?
Ive done that already, and even tried uninstalling other programs just to see if it is conflicting with some of my programs, by the way I have
1. irRemote
2. Launcher
3. Skin Editor
4. Bounce
5. Mp3Player
6. ScreenSaver
7. Forward
8. Pallette Extender
9. Contacts manager
10. Photo Editor
11. Active Desk
12. Cocktail
13. Video MMS
14. Photographer
15. Fexplore
16. Appman
17. And Stools
Still to no avail. 😞
Did the back ups, and formatted the phone. Stools works perfectly now. But I have a feeling that Seleq is responsible for such errors,... Or maybe a bad cracked program... 🙄
Kamalayan wrote:My Stools was working quite well when after a few programs installed it wont go to the Tools tab with out the "System Tools: System Error" message. Dang!
I had the same problem. Try the new version of STools 1.51(D). It works for me 🙄
_In case, i'd suggest you a complete format.
_Use the manual command *#7370# (default secret code: 12345)
_Don't forget to format your MMC then.
Regards,
Anh Tuan
