for 9210. Where i can find it? I tried from nokia web site, but no luck 😞
thanks in advance
Frank
thanks in advance
Frank
Multimedia Converter, no pro like you have written, can be found at the Nokia Forum web site (under Plug-ins):
http://www.nokia.com/phones/productsupport/9210/downloads.html
If you are looking for the Pro version, you have to go to
http://www.forum.nokia.com/
and then register yourself (for free)!
You will find the Pro Converter under Tools and SDKs (scroll a bit down to "Symbian"😉
HTH,
Tilman
It's best to use the pro version, check out this thread:
http://www.allabouter6.com/phpBB2/viewtopic.php?t=2165
Thanks guys! Nokia forum's link was dead, but I have to try later.
Frank
ps. kiitos vinkist� upponalle 8) Linkki ei toiminut, mutta yritell��n uudelleen.
ps. and others...that was "Nokia" language 😉
Forum link works (just checked it) or in Nokia language linkki toimii kyll�, ainakin pit�is... 😉
[quote="upponalle"]Forum link works (just checked it) or in Nokia language linkki toimii kyll�, ainakin pit�is... 😉[/quote]
Nokia loves Anakin Skywalker??? welcome to the darside... 😉
I've used pro for about three mobths and i can send it to you as email attatchmen.
olen kolme kuukautta k�ytt�nyt pro:ta ja vosin kyll� l�hett�� sen sulle vaikkapa s�hk�postill�, jos haluat.
Asia on vain sill� tavalla, ett� tuskin n�it� pro:ssa olevia ominaisuuksia kannattaa k�ytt��, videotiedostosta tulee nopeasti joko liian iso tai liian huonolaatuinen. Oletuksella on aina parempi tulos!
