Cool s.saver for 7650!
when i set it to animated clock, it seems like after a couple of second, the clock stop running. Any one see the same problem?
:roll:
Thats it 8)
lovely
S�mi
excellent! thanks for the post.
S.saver is only for 20 days... :cry:
The idea is good. However it doesn't give you the possibility of seeing signal power. Without that I think it's pretty useless. Just a little bit pretty
But u cant see it also with the original-screensaver...
one klick on joystick(also if your device is lookt,and u can hide the saver again.
Has somebody some real problems withit,or work it fine?
I was not happy with all of PsiLoc,but hope,they will not send us bugy SW in the future.
(why,they must use us always 4 Betatester?)
GreetZ S�mi
i got problem too
cause when the screen saver kick in, the back light always turn on
and i think it can reduce the battey life
anybody know,
whats happen with the startanimation?
will they overwrite it,like with the Task-manager?
Are there more Bugs out there?
if yepp,please post here down.
GreetZ from the sunny Basel
S�mi
In reference to the startup logo, PsiLOC have changed one of their libraries so that the Start Animation can be restored. I commented on this to PsiLOC and they released PsiNT eLib 1.39 very soon afterwards. Therefore, if you have Task Manager (for example - though this may apply to other application by PsiLOC), go to Options -> About -> Options and you should see a menu item regarding the startup logo.
In regards to other issues, why not tell them? This is becoming a standard practice for me now. When I try some software, especially beta software, I write them a little email detailing the bugs I've found (if any) and some stuff that I think would make the software better.
So far, this has proved very fruitful and I'm yet to come across a developer who doesn't respond positively to user comments.
PsiLOC can be contacted by e-mailing [email protected].
It would be interesting how much battery power the screensaver drains - each software running drains power by making the CPU work, and a screensaver is running most of the time. If this shortens the battery life I wouldnt run it only for optical reasons.
Maybe I am going about this the wrong way... but after a while the original screensaver kicks in over the top of the Psiloc version.
There is a new version of screen saver available (93 or 94), works realy well.
