ok..hope i can explain..
i have windows 98se and i would like to connect my nokia 3650 to my computer so i can share the internet access.can i do that..(go on internet on my 3650 throu my computers internet access?
help me please i someone know...
i have bluetooth on my computer...i can connect the phone to computer but i dont know how to "walk on internet",or even if its possible.
do i need any program on my nokia to do tath..well help me if somebody know..
sorry for my bad english
Yeah I would like to know that to.
Is it possible to connect NOKIA 3650 to Internet trought my PC ISP via bluetooth or IR? 🙄
Its possible,search the forums,there are couple of lenghty discussions on the subject.
I did it :tongue:
Just put IP adress:0.0.0.0 and ANP:none connect the 3650 via BlueTooth serial port like u do to connect to Nokia Phone Suite. Dial to ISP and that's all.
use netfront or opera to surf... 😃 :icon14:
Some application don't work,so do.Try Doris or Reqwireless WebViewer.
absi wrote:hey!
how did ya do it???i created a new connection in my phone according to your instructions, and connected the phone to the bluetooth serial port, but when i try to use netfront to browse wap/html sites, it connects to gprs tho i dint enter any apn. tell me in detail pls :frown: :frown: :? :?
I use NetFront(demo ver.) from here
It should be very simple. Just connect via bluetooth on u'r pc (seral port) and lunch NetFront or some other app for web surfing :tongue:
If any some troubles with appz feel free to PM me 🙄
bigforo wrote:I use NetFront(demo ver.) from here
HELLO BIGFORO, HOW ARE YOU DOING? I APPRECIATE YOUR RESPONSE TO MY PROBLEM. HOWEVER, I USE NETFRONT FULL VERSION. DOES IT MAKE ANY DIFFERENCE? I'D TELL YOU IN DETAIL THIS TIME. AS FOR A NEW CONNECTION YOU TOLD TO CREATE, I DID AS THE FOLLOWING:
CONNECTION NAME : BLUETOOTH LINK
DATA BEARER: GPRS
ACCESS POINT NAME: NONE
USER NAME: NONE
PROMPT PASSWORD: NO
PASSWORD: NONE
AUTHENTICATION: NORMAL
GATEWAY I.P. ADDRESS: 0.0.0.0
ARE THESE CORRECT? DO I NEED TO DO ANYTHING IN THE PC? AFTER I CONNECT TO THE BLUETOOTH SERIAL PORT, I DIAL TO MY ISP FROM THE PC, AND WHEN IT GETS CONNECTED, I OPEN NETFRONT IN MY PHONE, AND TRY TO ACCESS http://www.google.com/ FOR EXAMPLE, AND I CHOOSE THE BLUETOOTH LINK CONNECTION TO BE USED, AFTER A WHILE, THE G ICON BLINKS THEN IT GETS CONNECTED BY A SQUARE AROUND THE G ICON, THEN FINALLY I GET THIS ERROR MESSAGE AS FOLLOWS "ERROR: DNS HOST NOT FOUND http://www.google.com/". WHAT SHOULD I DO, WHAT AM I DOING WRONG? WILL WAIT FOR YOUR RESPONSE.
THANKING YOU,
ABSI
hi alls!
i'd tried the settings and it work perfectly, but i have one problem, i connect through opera and netfront, but they say memory full, so with opera i can't open the apps, with netfront, the app start but i can open only yahoo and google for example, but i can't open tim or other site because memory full.
what can i do for memory?
thx all.
the only difference with my setting is
CONNECTION NAME : BLUETOOTH LINK (i use BLUETOOTH)
ACCESS POINT NAME: NONE (i use "bt"😉
and it works but no memory 😞
Unonessunotutti,no real solution for the out of memory problem.The 3650 is very low on RAM,it has arround 3.4MB after bootup.Try restarting the phone before going online.
Unonessunotutti wrote:the only difference with my setting isCONNECTION NAME : BLUETOOTH LINK (i use BLUETOOTH)
Try using Flight Mode option from SystemTools app (psiloc). It gives u more free memory cause u r not using the SIM card (some system procceses r not started).
It works for me when I want to play N-GAGE games :tongue: and it should work for u 😃
absi wrote:ARE THESE CORRECT? DO I NEED TO DO ANYTHING IN THE PC? AFTER I CONNECT TO THE BLUETOOTH SERIAL PORT,
The serial connection must be done through mRouter (comes with nokia phone suite). The when u connect just start NetFront(no access point settings needed) and try to conneect on some wap page like wap.livescore.com :tongue: cause www page suck a lot of mem 😃 and be sure u'r connected on the internet on the PC side 🙄
hope that helps u...
bigforo wrote:The serial connection must be done through mRouter (comes with nokia phone suite). The when u connect just start NetFront(no access point settings needed) and try to conneect on some wap page like wap.livescore.com :tongue: cause www page suck a lot of mem 😃 and be sure u'r connected on the internet on the PC side 🙄
IT DOESN'T WORK AT ALL. I'M BEGINNING TO LOSE HOPE THAT IT WILL WORK FOR ME. I TRIED CONNECTING VIA PC SUITE CONNECTION AND IT CONNECTS TO GPRS AND THE ERROR MSG COMES UP LIKE WHAT I TOLD EARLIER. :frown:
absi wrote:IT DOESN'T WORK AT ALL. I'M BEGINNING TO LOSE HOPE THAT IT WILL WORK FOR ME. I TRIED CONNECTING VIA PC SUITE CONNECTION AND IT CONNECTS TO GPRS AND THE ERROR MSG COMES UP LIKE WHAT I TOLD EARLIER. :frown:
last time dude... :frown: DON"T use grps connection. If u'r using NetFront go to SETTINGS and scroll to CONNECTION, the Default Connection should be NONE... 🙄
bigforo wrote:Try using Flight Mode option from SystemTools app (psiloc). It gives u more free memory cause u r not using the SIM card (some system procceses r not started).
yes, i use for sonicN, but in flight mode no bt available. i tried to start the app bt but it didn't work 😞
Guys,lets keep this discussion on topic.Discussing pirated games is not alowed in the forums.
Unonessunotutti wrote:yes, i use for sonicN, but in flight mode no bt available. i tried to start the app bt but it didn't work 😞
That's sad :frown: bt connection suck a lot of RAM, olny WAP sites works. There should be a way to use disk mem as a RAM...
GhostDog pozdrav od SK :tongue:
No there isn't.Symbian OS doesn't support virtual memory.
i followed what you all said but i still cant... i'm using a nokia 7610 in singapore... i'm running on win xp sp2.. so i dont need to install the driver of the bluetooth... i'm using a billionton dongle... pls advice me what to do... the driver of the bluetooth is on the sp it self... :frown:
Hi ALL ,
i have the similar problemO , i created a default profile in my 3650 , installed nokia suite and bluetooth dongle on my PC ....i can connect my phone to PC well and good ...as long as there is no dialup internet conncetion ......
but if my PC is conected to internet , and then i conect my phone , using the USB bluetooth , to my PC ....the PC internet conection drops after some 20 or 30 seconds ...mRouter stays connected ...
can some one suggest a possible solution here , i am using a PCI modem .
Regards.
I am sending this message from my phone. Worst thing is typing and that i am doing this through 'ir'. Anyway it's cool
Can someone give me a link where this thing is discussed in detail.
or can someone post a step wise procedure for this it would be helpful
I want to use my PC's Internet on my 3650
Is it Possible with IR or only works with Bluetooth.
I have a MA-620 Ir Port.
Can it work with any Bluetooth Dongle or you require only a specific one.
If its only possible with bluetooth can you give me a name for a Bluetooth Dogle
with which you have successfully tested this browsing so that i can also buy it.
Which softwares are required for configuring this.
i have a 64Kbps Connection at Home which i want to share with my PC
i read the post but am a bit confused this is a very intresting topic and i am looking forward to your replies.
Added later
If i setup a bluetooth PC to Mobile connection and if i am having a webserver
running on my PC can i access that webpages on my Nokia 3650.
Using the various browsers that available on 3650
Try reading this thread and searching the forums on the same subject.
Hay....... try this link and down :icon14: load the modem software
removed
GOLDENEYE,reading helps.SymbianGuru is asking how to share his PC internet connection with his phone and not the other way arround.
