Whats the best task switcher/killer?? Free or otherwise? I think i need one for my 9290. =)
Thanks!
Thanks!
I have been using the task manager for some time it is a good app. but the new one appman is also good trying the trial version dont know if I wanna buy it or not, but it has more features than the taskmanager.
Switcher is a good free app. but doesnt tell you the free ram memory?
I think the appman will be the best app for now
Switcher is the free alternative for Task manager, only extra what taskmanager has is memory compression. I was very happy with Switcher, now I use appman 😉
Read the appman review here.
I have at the moment Taskmanager and Switcher and can recommend both. Switcher lets you nicely kill tasks, with Taskmanager you can do a compression as well.
I will test Appman next week or so and see if it is really as good as everybody says and if I personally have some use for it. Read Dazlers excellent Appman review. This will be a good way of helping you to find the application that suits your needs best.
[quote="Matt_Helm"]Whats the best task switcher/killer?? [/quote]
8) APPMAN Rules!!!
Thanks for the info. I'm messing around with APPMAN! 😃
😃 "Mess with the best, Die like the rest..." -Hackers 😉 hehehe...
Hackerz ... loved it 😊 Got that one in 80mb Nim format, but it won't fit on my 32mb mmc 😉
[quote="Nosferatu"] 8) APPMAN Rules!!![/quote]
Yes, it does!! Goodbye TaskManager and Switcher! Although they are not bad! 😉
There's also a freeware utility called iDisk that shows status of all 4 memory types. Howeverr, AppMan does this as well.
If the next release of AppMan delivers against the promises made, it will be the daddy!
