Hi
anyone can answer any of these questions ?
1)how can I download a C++ exe to a symbian device via the internet ?
( mime type configuration and what ever is related to this issue would help )
2)how do I get the symbian OS connect software ( which is used to download files from my PC to a symbian device ...) and with which connection does it work ?
thanks in advance
Make a .sis (Symbian Installation System) package (sisar or makesis or IDE tools).
Correct .sis MIME type is application/vnd.symbian.install
From a PC you can just use OBEX file transfer (over infrared/IrDA & Bluetooth) typically without any extra apps. Other than that, get the phone vendor's respective "PC Suite".
If Nokia, there is (or at least used to be) a "PC Connectivity SDK", too. Search http://forum.nokia.com/ for that.
thanks a lot ,
I will try these options.
N/A wrote:Make a .sis (Symbian Installation System) package (sisar or makesis or IDE tools).Correct .sis MIME type is application/vnd.symbian.install
Hey,
You can download an application to a symbian device without any special software. All you need is an IR or bluetooth adapter on your PC. You'd be best of if you used a notebook since most of these already have at least an IR port you can use to upload your SIS file to the device.
Regards, Aljaz
thanks
how can I use the note book ? (lost you there ...)
aljaz24 wrote:Hey,You can download an application to a symbian device without any special software. All you need is an IR or bluetooth adapter on your PC. You'd be best of if you used a notebook since most of these already have at least an IR port you can use to upload your SIS file to the device.
Regards, Aljaz
He meant that as a notebook has an Infa red port on it, you can beem your apps directly to your phone with it, without needing to buy adapters.
