I know that this has been asked plenty of times, but I haven't found a suitable answer.
I have N3650 with firmware 2.50
I was wondering, what are the advantages of a newer firmware. I have only a month of warrenty left, so if I want to do it, I must do it now. I heard that on 6600 with newer firmware the sending of jar files is disabled. Is this also on N3650?
Firmware upgrade
Its always better to get the latest firmwave even if it does have features which are disabled. There are always 3rd part apps which will do the samething anyway.
Perun wrote:I know that this has been asked plenty of times, but I haven't found a suitable answer.
That's very old firmware. 🙄
try using v.4.13 u'll like u'r phone a LOT 😃
bigforo wrote:That's very old firmware. 🙄
What is the difference? Any new features?
Perun wrote:What is the difference? Any new features?
More stable with some apps and u won't see that anoying SYSTEM ERROR! thing so offen... :tongue: but exept that it's the same Symbian 6.1 😃
Perun, about the details of the firmware v4.13:
Nokia Mobile Phones Service Bulletin No. 😃
SB-020/29.10.03 Call and network management
* GPRS over Bluetooth more stable on long connections (>2hrs)
Browser
* No longer sends UAProf twice after MIDlet-Install-Notify (part of MIDlet download)
* Byte-order-mark (BOM) used to detect content encoding in browser
* WTLS auto-accept anonymous connection now working fully (no longer asks user to accept connection)
* Cookie handling in browser improved
* Browser CSS, applied style changed from "screen" to "handheld"
* WAP post now sends input text as 16bit rather than 8bit
* Browser termination with "App. closed WSL_0S_Thread_1" fixed
SIM
* SIM ATK control of ALS functioning correctly
* CPHS CSP (Manual PLMN selection) now implemented
* Voicemail flag now written to SIM record 6F11
Messaging
* MMS editor: attaching objects no longer causes intermittent application termination
* Replacement SMS arriving while original being viewed no longer causes application termination
* Class 0 SMS with voicemail waiting indication flag handled correctly
* Java interactions with messaging centre when Ram is low no longer lead to abnormal application termination
Diverses
* Camera contrast and colour settings improved
* Memory corruption on start-up fixed (caused "contact service" lockout)
* MMC card no longer becomes unusable after removing password from locked card
* MMC card unlock requires share common text regardless of query originator
* Nokia Wallpaper images (*.nwp) can now be seen in the image gallery
haha alway update your firmware!!!
how can i upgrade my phone??
i�ve nokia 3650 with symbian v 4.13 isntaled in 20/08/2003 nhl-8 (what�s this sh...??? nhl-8???) but i wont to switch to a newer sotfware version but don�t nkown what to do!!!!!!!! is this possible???how can i do it.....
I just got my 3650, how to check what version is my N3650 firmware?
And how do I upgrade the firmware?
jojo888 wrote:I just got my 3650, how to check what version is my N3650 firmware?*#0000* & you upgrade by taking/sending your phone to your nearest Nokia authorized service center.
It would also be a good idea if you familiarized yourself with this useful site feature:
http://www.allaboutsymbian.com/forum/search.php
