New Nokia 6600 firmware 4.09,1
34 replies · 25,206 views · Started 08 April 2004
In Greece the new 6600 firmware has been released it improves some things as in Faster scrolling through menus,and unlimited vieo with sound using ETI Camcorder pro 1.0 version ... but also does some stupid things as in LOCKING the bluetooth and infrared for sending sis/jar/awb and midi files from your 6600 to another phone/or pc here are the details .. Changes/improvements made from MCU SW v 3.42.1 to v 4.09.1:
Call and network management:
Single connection tone during MO call
GPRS:
GPRS/PDP Context indicator
GPRS PDP context performance improved in cell reselection
SMS:
Character set issues:
Special characters encoded in Unicode instead of ASCII
Czech special signs
SMS sending via GPRS
SMS reading form SIM card
MMS:
Presentation improvements for messages sent from other vendor terminals (messages sent from e.g. GX10i, T68i, GD-87, myX-6, P900�)
Forwarding MMS when using content id�s in SMIL
Improved MMS ACK response handling
E-mail:
SMTP AUTH over TLS/SSL feature is supported
Improvements email sent using POP3
Browser:
Xhtml content is optimised with small screen
Improvements to handling Chinese contents
Increased URL maximum length
Interoperability with servers improved
Improvements in form handling
Resume browsing after received MMS
Browser input field �Go to web address� with special character
SIS -file download
Options in the browser are grouped under submenus
Improvements for browser stability
Streaming:
Support for multiple VOPs per RTP packet
Streaming performance improvements
MA Client Provisioning:
SMTP AUTH over a TLS/SSL feature is supported
JAVA:
Certificated Java installation
Support midlets with Chinese characters in the JAD
Java download handling improved
SIM:
SAT refresh functionality improvements
Dual-line SIM card
Enter MSTK menu after call attempt when FDN on
Voicemail spool fix
Voice commands
Bluetooth/IRDA:
Improvements for IRDA connection
Languages:
Arabic and Hebrew variants available
To: field default mode changed to numeric in SMS and MMS
Improvements to Phonebook entry handling
Operator menu-feature introduced
Binary compatibility break in HTTP framework removed (enables 3rd party applications (developed with SDK2.0) using HTTP via proxy to work)
User memory area (C drive) corrupting itself sometimes after format (2nd boot: �Contact retailer�) fixed
The Browser Application name and Help text update in Swedish and Ukrainian languages
IMEI SV number changed to �06�
That is nice!At least there is a "choice".Unlimited video recording or loosing 90% of your BT/IR functionality.
GhostDog wrote:That is nice!At least there is a "choice".Unlimited video recording or loosing 90% of your BT/IR functionality.
Well the way around that was to rename the sis file for example to .si and the other person can recieve it and open it with the ending .si and not .sis without renaming it back to sis as for midis /jar and awb just rename it to jpg or something and the recipent renames it with a third party app back to sis,jar,awb etc etc
There will always be a work-around but I find this limitation very stupid!
From all points of view.
Have you tried this or you are just guessing?
I renamed a mid file and it sent it w/o problem, after this I renamed it back and it works
GhostDog wrote:Have you tried this or you are just guessing?
uummm what do you think??OF course ive tried it,whats the reason mentioning it in here if i havent!!!!!
You're best off not even trying. If you find such, it is against the wishes of Nokia and probably also illegal in most countries. Using it also requires relatively expensive equipment.
If you want to have it on your phone, find the nearest authorized Nokia service center and let them upgrade your phone. Find them here:
http://www.nokia.com/nokia/0,,42096,00.html
Someone knows where can i find/dowload the new firmware ?
Federico
Dear Federico,
you can't download it.
You must bring your mobile to a Nokia Service Centre in your area.
If your phone is covered by a warranty it'll be free of charge.
If not they may charge a (small) fee.
(Something around USD 12 here in Turkey)
Anyway, think twice before updating...
Who wants it anyway???????????
v3.42.1 has a few problems (although i have been lucky and have only had 1 or 2)
v4.09.1 has been out a couple of weeks and the problems/edit of functions is already causing an uproar.
to find the firmware version of ur fone all you have to do is type "*#0000#" with out the quotes.
I'll stick to my version 3.42.1 until such time they figure it out or correct the problems on version 4.09.1 😃
just to say that i've got the 3.49.2 fimware version (20-01-04) (phone bought in France...) and i haven't got "factory" bugs.....
most of the softs works perfectly......and Bt & infrared works...
maybe a good alternative ?
ZeroHour - Anyone got any ideas if UK can get this?
yes you can..got mine done today as i was having problems with my old firmware...
Hi all,
I just got my Nokia flashed a few days ago... it was facing quite a few problems, mainly spontaneous reboots. However, the new version (4.09.1) seems to be worse.
The good part: the menus are faster.
The bad part: read on....
For starters, my startup graphic (the nokia tune with the video of the hands touching) seems screwed up. I saw a few other flashed 6600, they all had the audio only halfway thru the video, after which even the video seems to miss a few frames. Not important, but someone's not been careful!
My main worry is that even tho the phone doesn't seem to reboot when it's just lying there, it DOES reboot more often WHILE I'm using it. While speaking on the phone, many times the sound gets 'stuck', like a DJ running a very small audio loop... I can disconnect the call, but I have to restart the phone if I had to use it, otherwise it won't recieve/make any more calls.
Sometimes, while quickly scrolling thru the gallery, the phone reboots. If I do it slowly, it works... but when I use the stick to move down quickly, it just reboots!
I can't send any jar/sis etc. files, which is very silly. I have many game demos (such as Price of Persia) which I wanted to pass on to a friend, but I can't do that. Doesn't that hurt the software companies? I thought these things (specially local comm such as IR and BT) WERE meant for sharing stuff? The least they can do it to have the non-sharing constraint only on files that have copyright info, or maybe are specially marked?
A question: How the HELL do I save stuff from my Inbox to somehere I want, but not in messaging folders!!! I have some files I sent via BT. I was using eBook reader to access these files, but I have to go via the Inbox to use the file. Damned Messaging only allows me to make folders INSIDE messaging! And it's tooo much of a pain to use FExplorer to try to find the file, in the jungle of folders in the system\mail folder!
Last question: can I somehow get my last firware back?
In the New firmware version they have changed this:
"field default mode changed to numeric in SMS and MMS"
Here is my Problem:
I dont want to change to alphabethical mode EVERY time i�m about to send a SMS..
Does anyone know how to change the default mode to alphabethical?????
PLEASE!!!
//Peter
Dj_Dreamer wrote:In the New firmware version they have changed this:
Here is my Problem:
PLEASE!!!
//Peter
The only way you can do this,is by getting the old firmware! Ironic isnt it! 😊
elton wrote:The only way you can do this,is by getting the old firmware! Ironic isnt it! 😊
Yes very ironic.. =/
This firmware has been in Denmark from feb. 04. And it is not wery good !
A lot of programs will not install, or you can not delite incomming mail ect. ect.
