Does anyone know a decent USB to IR adapter for connecting my desktop PC and my N7650? I have some problems with matherboard IR adapter!😞
10x! Miro
USB to IR for N7650
Does anyone know of an INTERNAL IR adapter (that plugs into the motherboard). I have one in this room somewhere, but cant find it.
I have a clear computer case so I would prefer an internal adapter.
ohoh - miro_minkov, where did you get your motherboad IR from???
(USB one - http://www.dabs.com/products/prod-info3-info.asp?&m=y&quicklinx=2480)
I bought the Mobile Action MA 620 and never experienced any problems with it !
There are two places on the web ( cant remember where now ) that sell it for �31.95 delivered and are very quick to dispatch ( i.e next day ) alternatively you can pick one up from any carphone warehouse for �39.99
Hope this helps
Maybe it would be better to go BlueTooth...
you may get just as much trouble but all the best of luck ! PS aint Bluetooth like 4 times more costly ?
http://www.allabouter6.com/phpBB2/viewtopic.php?t=2142
[quote="Lydecker"]Does anyone know of an INTERNAL IR adapter (that plugs into the motherboard). I have one in this room somewhere, but cant find it.
I have a clear computer case so I would prefer an internal adapter.[/quote]I've had THIS one for a couple of years. It's perfectly ok with my good old Abit BX6-r2. But check out the whole site, there are other options, too..
