I have developed a little game in Flash and now am looking for a way to make it run on Symbian Mobile phones ( Nokia 60th and Sony P800/900 ).
How real do you think would be creating a Flash Player or a similar proggie to play *.swf files on this phones?
The one I found on the net is only for P800/900 and not very workable.
http://my-symbian.com/uiq/applications/applications.php?fldAuto=311&faq=2
My Screenshot:
Thanx! 😊
Ask Macromedia. They announced their intention to do so with Symbian already in 2001:
http://www.macromedia.com/macromedia/proom/pr/2001/fp5_symbian.html
Hey,
I remember seeing some .php scripts that were able to generate or play flash .swfs on the fly (check http://www.hotscripts.com/Detailed/26792.html for example) so it's probably not that difficult but writing an entire player is probably quite quite a lot of work....Take a look at the link above. Maybe you can try porting the player if you have enough time....
Regards, Aljaz
