Your 7650 screen shot!!!!
128 replies · 18,626 views · Started 17 September 2002
HI :P
just wondering how your 7650 screen looks like:P
you can take the screen shot of your phone using SeleQ:P
this is mine for the time being:P
what do you mean by you cant see mine?
i already put the pictures on my previous post, maybe your pc internet explorer is set to text only ?
AHHH APPLE SYMBOL ON THE PHONE!!!!
BURN IT!!!!!
[/ehehhe]
some intresting screenshots here, I quite like the first one.
Is it just me, but do other ppl have backgrounds on there phone.
Coz I made a folder where I got like 6 or so pictures to use as pbackgrounds, well not pictures actual backgrounds/wallpapers from PC that I use on my phone.
Anyone else sorta do this, or am I just trying to create windows on my lil 16bit phone?
Hei thx :P i can send you my pic files if you want to ;P
btw I also doing the same thing , i have a folder called background in my images folder . and i store 10 or more pics to be use as background there :P
But i just wondering is there any software that could rotate the background picture from that folder avery other day 😞
Hey OsirisMedia btw just checking with you, do you keep the background pics in 640x480 or 174x132 ??
Yeah ive been thinking the same thing, I have a sneaking suspcion that PsiLoc+ will not dounbt release and probably charge for an app to rotate the backgrounds but yes I have thought of it too, and if I knew what language and programs were used to compile apps for the phone I am pretty certain I could whip up a program for it, but I dont know so I guess well all probably be paying for an app to rotate the background daily or so.
Yeah I store them in 640 * 480, I found that the phone wouldnt make the background cover the whole edge if I didnt have it at that resolution. But yeah I have em at that resolution after spending half a day compressing the jpg as low as possible without loosing too much quality.
I think all my pics are roughly 35 - 50kb.
all :P , you can keep your background pics in 174 x 132 pixels and still have the pic till the edge of the screen :P but the quality will be lower
but hey!!!
its only about 6 to 10 kb per pics!!! :P
really
hrmm im not surprised it was just on some occasions when I had a pic under 640, it seemed to not go all the way to the edges.
but yeah I dont think ill sell out that much image quality. I like my backgrounds to look impressive, especially on the LCD screen, wont be tgat impressive if there distorted and disorientated.
Ok, what am I missing...
How are people getting graphics on the top bar of the phone? Like the sunnies, or "Armageddon" graphic, etc.
Tried playing around with settings but didn't find anything intuitive.
Can you tell us (and specifically, like where in what menu does it allow it?)
thanks! 😮
im not 100% sure but im fairly certain they are the Operator Logos. its just you can put pictures as operator logos on the colour phones instead of those 2bit dodgey lik black and white pics you usew to be able to have as operator logos.
Warning! Bible Basher alert!
But seriously, this is my current screen and I echo AnlaShok request, someone write a random wallpaper changer!!!!!!
Tanker - makes me think of one of those classic T-Shirts I saw once
Jesus is coming (on the front)
Look Busy (on the back)
I'd get get bits amputated if I did 😮 😮
Anyway less of the porn, she's my bird, I have exclusive rights to her body parts.
I thought this was a phone forum!!
[quote="J2theIZZO"]I'd get get bits amputated if I did 😮 😮
I thought this was a phone forum!![/quote]
Hey, I'm sure it's flexable - the mods dont mind :roll:
