any idea what the hell this app.main closed is everytime i go to open my phone 6600??
APP MAIN.Closed????
john74 wrote:any idea what the hell this app.main closed is everytime i go to open my phone 6600??
I have same problem.....help us..
Iscio wrote:I have same problem.....help us..
This bug is because the Sms-report.
only deactivate it, and the main-error is gone.
S�mi wrote:This bug is because the Sms-report.only deactivate it, and the main-error is gone.
I get this now and so does my mate on his 3650. We're both on o2 network. I have double checked and sms-report is off, o2 doesnt support reports anyway. Weird.
m_aird wrote:I get this now and so does my mate on his 3650. We're both on o2 network. I have double checked and sms-report is off, o2 doesnt support reports anyway. Weird.
Mmmh, weird, at my friends phone this was the reason 4 this main-error...
My 6600 never have any problems...
maybe it would be the best way, to remove all the apps, make a backup and then format first the mmc and later the phone.
(dont forget to delete the password 4 the mmc, if there is some, and full up the batterie bevore the hardreset.)
Know u can restore all the contacts, mails, etc, but dont activate the button with all datas and settings, only activate the buttons 4:
the contacts, Calendar and Datas and picture to save them back.
(like this the error will not be save back on phone.)
at last u can install all the programs u need again.
like this the error should be away.
:icon2: PLEASE HELP ME! I am an Italian and you excuse my bad English but I am in despair ! I have a NOKIA 6600 and when ON phone appear the Err Message: APP MAIN CLOSED thing I must do? how can I solve it? please help TANK there!
(dont forget to delete the password 4 the mmc, if there is some, and full up the batterie bevore the hardreset.)Know u can restore all the contacts, mails, etc, but dont activate the button with all datas and settings, only activate the buttons 4:
(like this the error will not be save back on phone.)at last u can install all the programs u need again.
i am using a N3660 and had experienced the same problem some time ago. i first noticed the problem when i tried to add voice tags to my contacts. initially, i thought it was the apps that i have installed that is causing the problem. thus, i formatted my phone. i did not install any app after that. i have managed to add some voice tags to my contacts before the same problem came back.
i am running out of ideas here. i have been thinking of upgrading my firmware. then again, i just got my phone some two months ago. any suggestions from you guys in here?
in which menu can I deactivate the sms report, I use a german version of the OS.
Bernard
Messaging -> Options -> Settings -> Text messages
N/A wrote:Messaging -> Options -> Settings -> Text messages
hello all very helpful forum, i have the same prob with my phone all of a sudden and i tried stopping the sms reports but it still does the same message at start up, and sometimes all of a sudden programs stop working for no reason the try to open then just go back to menu would appreciate and help largyros
It's nothing to do with SMS reports...
I have the same problem, and never use SMS reports.
Looks like bugs in the firmware.
Is this also happening with the V4.xx firmware ?
technik wrote:It's nothing to do with SMS reports...I have the same problem, and never use SMS reports.
Well guys I had this problem on my SX1 and it dissapeared after removing some Psiloc Apps. I don't remember which were the exact apps.
After all I had many problems with Psiloc's Applications, and I am sure the problem is related with at least one of them...
There are a lot of reasons that can cause this mysterious problem.
(Yeah, it is like the Blue Screens in Windows 😃 )
Bad applications, or even files.
For me, it started when I back-uped (by copying) a file from the System\Apps folder to the a personal folder I have created with the name E:\Documents.
I could never imagine that this could be the reason, but when I deleted this file from E:\Documents, the error stopped.
nickg78 wrote:There are several reasons that can cause this problem. Bad applications, or even files.For me, it started when I back-uped (by copying) a file from the System\Apps folder to the a personal folder I have created with the name E:\Documents.
thanks all for the help dont know much about controlling these darn new inventions so i go crazy with different programs and something in there must have screwed the rest up,
also any one can tell me how i know what version of firmware i have on my 6600
thanks again take care :icon14:
Just do *#0000# on your phone and the firmware version will show. The latest I think is V4.09.1 ( had mine done on Saturday).
Doug
dougproctor wrote:Just do *#0000# on your phone and the firmware version will show. The latest I think is V4.09.1 ( had mine done on Saturday).
Doug
thanks again for the help, it seems i do have an older version of firmware from oct. 2003 so i guess i will somehow have to have it changed, does nokia give it out or i must purchase the setup from them largyros 😉
