.WAV buggin me now need help.
3 replies · 1,560 views · Started 21 April 2004
ok so i put this mail6a.wav file into my sound gallery in digital folder. so now when i try to play the file it goes like file not supported. i was like ok and i wanted to delete it by now and this is worse, i cant seem to delete the damn file at all. now this is buggin. it shows me all sorta errors every way i try to delete. it shows file protected and crap. so far i tried deleting from the main folder itself no luck, then the file manager by nokia still no luck, then i put seleq and tried it still says protected file or in use when its not really. i really wna get rid of this file is there ne sorta program or nething i can do to get rid of it. plz plz help. im stuck. thx in advance.
Jesal wrote:ok so i put this mail6a.wav file into my sound gallery in digital folder. so now when i try to play the file it goes like file not supported. i was like ok and i wanted to delete it by now and this is worse, i cant seem to delete the damn file at all. now this is buggin. it shows me all sorta errors every way i try to delete. it shows file protected and crap. so far i tried deleting from the main folder itself no luck, then the file manager by nokia still no luck, then i put seleq and tried it still says protected file or in use when its not really. i really wna get rid of this file is there ne sorta program or nething i can do to get rid of it. plz plz help. im stuck. thx in advance.
have you tried using FExplorer v1.10? i've found it to be the best file manager.
got the problem fixed and no i havent used the fe explorer. i use seleq instead . is it free? if yes can u post it here plz . thx
