I'vew downloaded the HTTP Client example from Symbian.com, but it doesn't run.
How can I get and test an HTTP onnection on the Series 60 emulator?
HTTP connection
try to go to the corej2me site and check the Http examples.
http://www.corej2me.com/DeveloperResources/sourcecode/networking/fileViewer/index.shtml
hope this helps ...
_Fox wrote:I'vew downloaded the HTTP Client example from Symbian.com, but it doesn't run.
I tested mine on Nokia 6600.
It works well, provided that the access point is set correctly (I had mine stuck for some time because an access point that works with 'Services' application does not necessarily works for Example Client).
