copying mp4 to PC without e-mail
6 replies · 2,421 views · Started 20 September 2002
if you don't want to e-mail mp4 files to your pc:
Just down load and install Forward (which is free), create a dummy e-mail from the video software but don't send it.
Run Forward and send the video to the PC via bluetooth or irda. Then delete the e-mail that was not sent from the draft folder.
Bit longwinded but doesn't cost anything this way.
😉 Juste make a backup with Pc Suite and then go in the folder of your Pc
c:\nokia\username\backup\internal\videos !!!
and you have all the videos on your PC.
I think someone has mentioned this already but the quickest way to transfer video is to just download a filemanger for your 7650 and open the 'video' directory on your phone. You can select the video file and send it via bluetooth or IrDa to another 7650 or your PC.
dAMN YOU people with ya Bluetooth and ya Irda's
all I gots is me emails
and after next month ill have to pay for it all 😞
If you're in the UK an infrared adaptor is only �26.70 and a bluetooth one, only �34. Both from ebuyer.com
If u would like 2 save some more space in your Phone-memory,
Take the programm Forward:
its only 7kb!! and work the same good,as the Filemanagers.
It is a small Prog.that only move forward all the Datas;
they are somewhere in the Sms/MMS/Mail-prog.
That works via:
Bluetooth,infra or Mail
so u must only send the mp4 from videoprog to Mailbox,(senden)
then u can send it out with the forward.
hope u understand what i mean 😉
S�mi
That forward program looks like th emost useless program I have ever seen,
eitherway im in a catch22
1. I dont have an IRDA or Bluetooth device
2. I can use mailboxes on the phone but cant send out from them, only recieve
3. My free trial GPRS period will expire early next month which means it will cost me money to send this vuia email if I get the outgoing mail working anyway.
Actually I guess that isnt a catch22, just means ill have to biy a bluetooth device hey, or they could enable MMS sending of this.
