send files? please help!
9 replies · 2,958 views · Started 08 May 2004
PLEASE PLEASE PLEASE!!! could someone someone tell me why I can't send files on my 6600 the same way i did on my 3650? If i go into Fexplore or SeleQ and send any file that is not a picture, it just does nothing, no sending progress bar or anything, not for infared or bluetooth. Pictures send the same tho, please could someone suggest a way to send any type of file?
Many Thanks
Wisebeuy
[QUOTE=wisebeuy]PLEASE PLEASE PLEASE!!! could someone someone tell me why I can't send files on my 6600 the same way i did on my 3650? If i go into Fexplore or SeleQ and send any file that is not a picture, it just does nothing, no sending progress bar or anything, not for infared or bluetooth. Pictures send the same tho, please could someone suggest a way to send any type of file?
if your send files for you 3650 on the same pc than you should have no problem with 6600.
have you installed pc suite for 6600 if no i think you should do it.
have you paired your computer with 6600? if no then you need to do it using bluetooh on your pc or 6600 so you do not have to look for your 6600 every time you want to send a file.
you need to autherised your 6600 with your computer you can do it by 6600 or pc that would make your 6600 accecpt files from pc without asking you every time.
also if you have firewall check it and see if it conflict with nokia pc suite.
I hope that helped
hazeman
I meant sending files from one phone to another. it seems that .sis and .jar files are the main ones that won't send
any programs i can download to do it?
wisebeuy wrote:I meant sending files from one phone to another. it seems that .sis and .jar files are the main ones that won't send
I know how to do it with several ways,
using seleQ, fexplorer or another one programm
As petran says, the reason is in that link. And a quick solution could be renaming the file, by example, deleting the dot, then send the file and when the file is received rename it aggain putting back the dot. I can do that on my 6620.
want to send .sis or .rar files via bluetooth?
very simple JUST AND AN EXTENSION
goto RENAME CHANGE .sis as .sis_or
Use search. Key in "Corrupted MMC fix" by me. If u find it, the "7tools" can browse MMC so necessary data can be saved.
Good luck 😊
