Hi! just some of my small contributions. enjoy it!.. however, you may send me your require icons and I will try to make it for you.
many more to come!
regards,
william
many more to come!
regards,
william
welcome back... bring it on baby... 😉
Nice stuff! 😉
Keep up the good work!
and cool avatar u got there too... hehehe...
thank you guys, :P anyway, the second set will here shortly. take care. 😉
Maybe use some more masking? Looks good btw 😉
Thanks you for the comments Dazler, I really need to improve it for sure. Because I realized that the color is not that sharp enought. isn't it???? it fade a lot!!! Why!
Please advice... :cry:
The main reason will be that the 9210 only can display 4096 colors.
You are right... I will try to use more masking on my next pack. Thank you. 😊
[quote="n9k"]Hi! just some of my small contributions. enjoy it!.. however, you may send me your require icons and I will try to make it for you.
many more to come!
regards,
william[/quote]
Pardon my ignorance but where can i can get your icon packs? thanks.
[quote="apcaw"]Pardon my ignorance but where can i can get your icon packs? thanks.[/quote]
It is in the first message of this topic... 😉
Hi!, apcaw I guess you need to login in order to download the pack. anyway here is the second one.
Just hope you guys like it.
Thanks. :roll:
Nice 😊
I noticed you used /c16 for every picture you convert.
Included in this post are your 2 archives in 1 archive with more appropiate settings:
/c16 for the colour icons of the first set
/1 for the masks
/c8 for the cartoon icons
Greetz and succes
Thank you for pointing out. I really do appreciated it Dazler. You are right. 😮ops: I will do it better next time. for sure!
thak you Dazler!
Now Roadrunner is "running" around on my memory card... 😃
Keep up the nice work!
More!!! More!!! More!!!
some perverted stuff plizzz.... heheheh... 😉
ok Nosferatu, I will try to get one for you!!. give me some time ok..
[quote="Nosferatu"]More!!! More!!! More!!!
some perverted stuff plizzz.... heheheh... 😉[/quote]
Did I expect anything else from you... 😉
Lucky for us SAM the sheep yoda was not around... or else...
there'll be some sheep request too... hehehe... 😉
OK,
I did download it.
How do I put them on my 9k?
I know i read somewhere in this forum about it, but you know, sometimes is easy to wait for the answer... 😮ops: :cry:
it's in the readme's he supllies.
Just copy the extraicons.mbm to c:\system\apps\home\
And be sure to first copy your extraicons.mbm file to your pc
Thanks Dazler "Just copy the extraicons.mbm to c:\system\apps\home\ " for the clarifications.. 😉
I would have said RTFM, but since I'm still writing the manual it would have been hard for him 😉)
some additional side picture for today. hope you guys like it? just for guys" I ment!! 😃 for this forum is this ok???
No problem, since there are not many girls here 😉
OK! which means we can go further right.. ha ha ha :P
Many thanks!!! bring it on baby... 😉
"Terima Kasih Daun Keladi,
Jika ada tambahlah lagi!!!"
Hi!
Here is another set of Icons and picture packs. Hope you guys like It!
thanks.
I can't change them on my 9210 all the time with your creation speed... 😉
don't worry upponalle all your problems will be solved by me in a matter of a few weeks 😊 8)
