Does anyone know if it's possible to develop C++ applications for Symbian using Eclipse with the CDT plugin? I'm used to using eclipse and don't really want to have to learn a new IDE. If it's not possible, what IDE would you recommend?
Eclipse for Symbian
Hey,
There are three major IDEs for Symbian platform Microsoft's Visual C++, Borland's C++ BuilderX and CodeWarrior. They each have their pros and cons. VC++ is reportedly the cheapest and quite easy to use, BuilderX is more RAD orriented even including a graphical tool for constructing dialogs and other GUI elements while CodeWarriror is reportedly very easy to set up. It's up to you to decide which one suits you best.
Regards, Aljaz
It is possible with this plug-in: http://www.newlc.com/article.php3?id_article=497
