GPRS Mb question
11 replies · 2,108 views · Started 22 September 2002
just curious about how many Mb if i just using GPRS for mail and surf via wap not often i guess
cos i want to apply for GPRS
oh yeah also for the MMS thingy
I'm not using GPRS for mail, but I think 5mb would suffice if your not sending loads of programs ect. (If you've got BT/IR)
I have GPRS on my V66, which i use for WAP daily (checking email, football scores, ebay auctions and news) I have an allowance of 1mb which I have never even come close to passing in a single 4 week period. I'd imagine email would bump it up quite a bit, so something like 2mb should be enough. Like J said, if you're downloading programs your needs will differ, then you should start looking at 5mb+
well i just got it today and already in 15 mins used over 1.5 mb !
But i was using Webviewer with images turned on !
WAP Pages are really small ! Again tho m8 it depends what you are after it for !
The good thing with the e-mail app though is you can check its size before downloading it - just in case some idiot has sent a load of attachments that would be better delivered by White Arrow!
No, if you go to ptions with an e-mail selected, you can view Message Details and if you scroll down from there, you can see the size of the e-mail.
I used to use GPRS with my palm via bluetooth, now with my 7650. On an average my e-mails were about 10kb each. So if you work by that principle.....
But my understanding is that if you have a POP3 serivce you never get to see the size, they just start downloading on connection. What you have just described is a facility of an IMAP4 client talking to a server enabled for same. Otherwise, Y would people bother to set up IMAP4 ...
[quote="erhum"]But my understanding is that if you have a POP3 serivce you never get to see the size, they just start downloading on connection. What you have just described is a facility of an IMAP4 client talking to a server enabled for same. Otherwise, Y would people bother to set up IMAP4 ...[/quote]
Well, I'm definately on POP3 and I only download e-mails that I am interested in, and that are not stupid sizes.
My usual procedure is;
1) Open Messaging, go to the mailbox (my case, ADDR.COM)
2) Options -> Connect (wait for mailbox to load with mail headers)
3) Ooh! There's an interesting looking e-mail. Highlight it
4) Options -> Message Details
5) Scroll Down - Only 73Kb, that's Ok with me
6) Select Ok
7) Options -> Retreive E-mail -> Selected
8) Disconnect
9) Read my mail
Sowted!
I have just signed up for GPRS Orange 0.5Mb per Month.
I an ONLY using it for email send/recieve with image attachments from my camera.
I estimate that this will allow me to send 20 images per month - is this correct (do it sound right to you?).
THanks.
Tanker - Hey I am no expert ... just that was the way I thought it worked. Sounds OK to me ... I'll just have to sort out a global provider then and set up my rules in Outlook to forward on to me only those that I might be interested in (seeing as how my ADSL service downloads everything every few minutes).
Thanx
