Hi, just got a 9290, and so far pc suite can't open calendar on the communicator even though i can see it on the pc and have selected it. It does synch contacts. Any solutions?
Can't synch calendar
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Have you adjusted the calendar sync task on pc quite ?
yes, thats been adjusted - any other suggestions?
thanks
n8yrm8 wrote:yes, thats been adjusted - any other suggestions?
thanks
Depends; what's the exact error you're getting? Also, it would be helpful to post some details about the synchronization task settings and the actual file locations on your communicator.
its says: communicator unable to open file: C:\system\data\calendar
n8yrm8 wrote:its says: communicator unable to open file: C:\system\data\calendar
I have same problem but I don't have a folder named "C:\system\data\calendar" in my hard disk
Had the same problem and this is how I fixed it, format PDA and reinstall the all_data.sis file and remove/reinstall the PC suite on the PC. 😊 also you have to remove the folder called Nokia which is in the C drive.
lonegunman wrote:Had the same problem and this is how I fixed it, format PDA and reinstall the all_data.sis file and remove/reinstall the PC suite on the PC. 😊 also you have to remove the folder called Nokia which is in the C drive.
have the same problem ... where can I find the all_data.sis - and what will it do ?
txs Giretz
