As far as I understand, the T-Mobile video application for the 7650 only supports sending video clips as emails. Sending from a file manager doesn't work either. I suppose sending the clips as multimedia messages would require additional software...any ideas whether such SW is available and where? Thanks.
Sending video clips as a multimedia message
Yes no at this stage it is not possible
the phone and the server verify the data being sent in mms messages. and as of the momment there is not the software of hint of stoftwarte to come that can chnage that.
Bad news hey
but justr send via email or buy a BT or IR device.
you can email your videos as attachments (not mms) then view them on your pc with divx player...
use seleq to do this..(providing youve setup your email) 😮
ppl its possible to send as mms:
just rename the mp4 file to jpg and send the video via mms but as jpg works for me :PP then just user seleq to rename to mp4 again :P
EASY :P
😊 Etchulente ! 😊
No, it does not work (at least not with v 3.16). When trying to insert the .jpg to the mms, it says it is corrupted or the format is not supported. 😞
Indeed other ppl have reported the file corrupted, what version are you using where you didnt get the file corrupted message??
I am using 3.12 and i did not get the file corrupted error
sweet thats the versionb im running
ill go give it another go.
it works for me :P i am inn3.12
yepp tried it yesterday
3.12
works fine,. renamed file, away it went.
i try to insert a video file made at hantro, into a mms and it dosen�t work(file dosent suported...). my version is v 3.12, who said that it works?!
