Email problems
2 replies · 820 views · Started 20 June 2004
Hi peeps
I have the 6600, my problem is that i can send emails from it but when i try to recieve all it does is keeps trying to connect and nowt comes down!
It did complete once bit took about 5 mins and didnt find any new emails and i know there was 1 as i sent it to my self from the PC....Any ideas?
Regards
Bashy
GRIM REAPER wrote:you need to make sure you have the right settings. go here & try the settings they send.
Hi peeps
Have sorted it now....thanks for you input
Regards
Bashy
