plinkykev wrote:Hi dragon. Sorry, forgot to reply to the other bits of your post!I�m not sure about the ��lost two customers�� that you mention, as I believe that those orders (and a lot of others) are still going on OK.
I know that demand has been high for the Sendo X, so maybe it�s a case of late, rather than lost.
As to servicing, the guarantee certainly DOES cover Europe, so a handset could be fixed in any country that has a Sendo service centre, regardless of where it was purchased.
Should the handset need a software upgrade, the update system is designed to re-load the latest version of that (operator) version that is already on it, so again, should be OK anywhere, being a web-based system.
Indeed you can do this from home yourself, via the USB cable, so a service centre should even not need to be involved (unless you totally killed it somehow!)
Well, about the guarantee issue, that is nice to hear. I'm fully aware, that the X has a home update feature (files are 30 MB, latest build is 47G dated 30.06.2004).
And yes, the demand for the X is high. It is a GREAT device, there is NO doubt about that. And at the time, the X will be available in bigger quantities, you may show Nokia what a Series60 phone is supposed to be 😃.
You people at Sendo did a great job so far. And as i said before, all the problems are forgiven, the day the X will be shipped in bigger quantities.
About the "Themes" issue, did you include a special API in the developer kit for themes on Sendo X Series 60 1.2s?
As far as I know, Series60skinsupport is included only in Symbian 7.0s Series60 V2.0. So did you wrote your own kind of skinsupport?
I know, that it IS possible to included "full scale" skinning of Symbian 6.1, but you have to go quite deep into the core system to support that.
All the other theme support software (Smartlauncher and Trigenix) are only some sort of GUI, they are no real themes...
Would be great, if you could send me more details as I'm a registered developer.
Thanks for your help and contribution here!
Btw: Are you a Sendo X developer?
