Mobile blog from Communicator
1 replies · 2,451 views · Started 02 July 2004
Hi all
I tried to do some blogging from my Communicator. There are two tools available for that, Azure and Blogplanet. With MIDP beta from Nokia they both load perfectly on the Communicator and everything works (accessing the blog on the server, getting blog entries etc), but as soon as I want to send something to the server, it fails. Azure says: "An error occurred: null" and BlogPlanet gives me the following error message when sending a blog entry:
"Couldn't connect to server: Application failed during request deserialization: xml declaration not at start of external entity at line 1, column 512, byte 512 at /usr/lib/perl5/site_perl/5.8.1/i686-linux/XML/Parser.pm line 187"
This make complete sense (but not really) to me. Anyone knows what this means or how to solve this problem?
That could be an error with server - with the XML RPC part of the script. It might be worth checkin got see if you can blog use a desktop tool of some kind. However thinking about it its a bit unlikely since you've got it to perform some of the other functions (retrieval etc.). I suspect its a broken implementation of network sockets of the 9210
