Hi all
I look for data and code examples regarding sending data via gprs (simple String data) , any data can help me !!!
Is a TCP/IP example good for using via GPRS ?(I know that this might sound as a stupid question 😊 )
Thanks a lot
Hi all
Thanks a lot
Yes, a[ny] TCP/IP example is good for using via GPRS, because GPRS is transparent to you/an application.
do you know of a good example ?
N/A wrote:Yes, a[ny] TCP/IP example is good for using via GPRS, because GPRS is transparent to you/an application.
Good is a subjective term, but search on these sites:
http://forum.nokia.com/main/0,,1_32_30,00.html
http://www.symbian.com/developer/development/index.html
Thanks again 😊
